hi all, just at the stage now to put window boards in my new conservatory. I am just asking for suggestions as to what timber to use. I could use pvc but i think it will look cheap and tacky, so i thought use mdf board but not sure if it will warp and bow due to moisture, sunlight etc... i have put in a 100mm cavity between walls and filled the cavity tops with the 25mm cavity closures to try and stop alot of moisture rising up. If I use mdf what is best to put on it to help it with the moisure, maybe gloss the bottom of the board aswell?
any comment will be much appreciated
cheers
andy
cheers
andy
