MDPE Joint Under Suspended Floor
25 Jun 2008
Southampton
Hello is it okay to have a MDPE coupling joint (https://www.screwfix.com/prods/17684/Plumbing/Water-Pipe-and-Fittings/MDPE-Coupler-25-x-25mm) under a suspended timber floor?
I hope it is because it would be a nightmare to replace now since it's all fully laid ready for mains connection now
I plan to have a real wood floor on top so wanted to be reassured
I'm sure these joints are common aren't they otherwise why would they be sold right? :roll:
Someone please reassure me :( pleesh
It will be ok under a suspended floor, but I would never fit one where I would not be able to gain access easily at a later date. Is it possible for you to cut a board to make it easily liftable in your new floor, cos it would make a heck of a mess if it started to leak.
Remember not to overtighten the coupler as they are only plastic threads: follow the manufacturers instructions from their website if you are in any doubt.
:roll: Thanks for the info Mr Leaky, well I'm not sure whether that's good or bad news
It's not in solid floor or soil BUT it is under what is to be a solid wood floor which will probaly be secret nailed to the floor
That's an excellent idea of cutting a board, I shall cut the tongue of the boards above the joint so hopefully if needed they can lift up without too much damage :oops:
But from your experience have you heard of a mdpe coupler joint failing?
Is it worth smearing some silicone gel on the joint?
Thanks for your help sir
