Measuring up for replacement quadrant shower enclosure
11 Jun 2012
London
My bathroom already has an quadrant shower enclosure but the door is now broken so I need to replace the enclosure it, the brand of existing one is Ocesana, I'm not replacing the tray.
I looked online and the quadrants seem to come in standards sizes of 800, 900 and 1000mm. I measured mine though from the corner of shower (tiled wall) along the wall to the where the existing ensclosure met the shower tray and it was 834mm, I then measured from the corner to the edge of the shower enclosure so 45 degress across it and thats come in at 1000m, is the second measurement the one I should go with, or is it the 834mm ? Or could I just have an odd shaped shower tray and cubicle ?
thanks
I found a label on my current enclosure and now know its of a 900 x 900 mm size. I also identified that the old enclosure has a radius of 540mm, where the enclosure meets the tray there is about 1.5cm depth left to the outside edge of tray.
I've been looking at new 900 x 900mm enclosures and all of them quote a radius of 550mm I cannot find a 540mm, would I be able to fit an eclosure with a 550mm to the existing tray without it looking odd, will it just be the case that the enclosure is closer to the outside edge of the tray than it currently is ?
thanks
