As I understand from the building regs my external walls should be atleast 0.030 W/m2K.
My builder is building the extension walls with outer brick leaf, 100mm cavity, inner blocks are concrete the heavy type . and we will use bonding and plaster inside not plasterboard.
Now I have used the cba-concrete blocks association website (http://www.cba-blocks.org.uk/tech/tech_uvalue.html) to get an idea what type of insulation I need and as long as I use 100mm insulation with 0.034 W/m2k value I achieve 0.30 for the wall.
My question therefore is that is this correct? The concrete block thermal values I dont have so I have used the default ones in the calculator but I would like a second opinion from one of you knowledgeable people whether I would achieve 0.30 with concrete blocks and the insulation I intend to put in.
Many thanks for your help
