Mega Flow or Vaillant Eco-Tech plus 937 combi boiler
15 Nov 2005
Looking for some advice. I was thinking of installing a vaillant 93 combi in my house (1 bathroom, 1 en-suite, 2 toilets). I know its large but I have the space and wanted becuase of its storage tanks and the fact that I could run a bath (in the bathroom) and shower in the ensuite without it affecting the water temperature or pressure. However, recently someone told me about that a mega flow system might be better. I'm having work done in the house so building control is already involved so I dont think that side of the thing will be a problem. But I just dont know enough about a mega flow system - its benefits, cons, etc to take a decision.
Anyone here have any experiance of both systems, what would be best for me? The house is a 4 bed and will have 3 adults and 2 kids
what flow rate do you have into your property ? the pressure and flow rate are the most important pieces of information when deciding what kind of system your going to have installed, have these checked and ask again.
Not sure about flow rate...but I am having my connection from the main redone again in 22 or 26mm pipe - sorry if it sounds a bit dumb
Flow rate, flow rate , flow rate.
The size of the pipe is often bandied by installers as the magical solution. It isn't.
Your flow rate will be decided by the water supplier, your pipe sizing merely helps you optimise what is available to you.
Make sure you know what is available, before making any big budget decisions on equipment.
That's a little hopeful. Forget the boiler, you would need to carefully specify your pipework to avoid the shower flow rate dropping when you ran a bath.
The boiler is a 37kW combi with a small storage tank (only 15l!) so it can boost flow rates to 20l/min (30 degree rise) for a short period. Long enough for a shower, but nowhere near enough to supply a shower and run a bath at the same time. Depending on your shower flow rate, you could shower and run a bath quite slowly, but then what would be the point of that?
