Megaflo heated by electric
18 Jun 2007
Sussex
im not sure if im the right forum!!
I have a megaflo which is heated only by electric and cant seem to get any hot water. Does anyone have any problems like this??
Would be grateful if anyone has any advice
So its heated just by the immersion heater?
If so, check the switch is on for the immersion and that the fuse/contact breaker in your fuseboard hasnt tripped.
Anything after that, you'll need an electrical test meter. Come back after you've checked the above.
It isnt the immersion, its the Megaflo safety cut out.. this is usually wired into the boiler circuit to cut the boiler if the Megaflo tank goes over temp.
I guess it could be wired into the immersion to provide the same facility - never seen it done though.
