Hi eveyone I'm in a real pickle and needs some advice.. the ear ache I'm getting from the wife is killing me.
I have a three story property with a MegaFlo unvented hot water system with expansion vessil and all those clever bits and pieces. I have some really anoying intermittent problems with water pressure and flow.
At some points the hot flow drops to zero (nothing out of the tap) after just a few seconds of the hot water running fine at high flow and good pressure. I have tried re-energising a few times and it sometimes helps the problem however it is not a permanent fix and currently we get around 60 seconds of good flow and pressure before dropping to almost zero.
I am wondering if there is a blockage in a filter or something that could be preventing the pressure remaining high once the hot tap is in use, but I'm only a DIY plumber and don't really have any experiance with this sort of system. It seems to take a while to build the pressure back up and we have the same problem all over again. We get some real funny noises from the airing cupboard when using cold water in the house - does this mean anything?
