Hi folks, need your assistance with this.
A megaflo is being installed right at the other end of the house to the central heating wiring & boiler. (To serve shower & bathroom at that end).
The plumber has put a two port valve that is supposed to shut if the cylinder goes over temp (thermal cut out).
There is a handy supply near the Megaflo but its impossible to run control wires right back to the programmer.
Am trying to work out how to wire the valve to the megalfo thermal cut-out & thermostat connections. Is it simply:
Live to terminal 1 on thermal cut out block
Brown on valve to terminal 2 on thermal cut out block
Neutral to blue on valve
Grey & Orange not used on valve?
I think then if the thermal trip is in normal the valve will be open, if trip operates the supply to valve will be cut & valve will shut.
trying to work it out from the wiring diagrams in megaflo installation book but they only show S & Y plan wiring and doesnt cover this situation.
Grateful for your help!
TTC
TTC
