I have a Megaflo CL210HE unvented hot water system.
When the hot water is switched on, I get water trickling out from the discharge pipe. I have followed the procedure in the Installation Manual to recharge the air volume. When I do that, the system is fine for a few days, but then the water starts to come out again.
I can see the water does not come from the Temperature/Pressure Relief Value as the turndish area is dry and the water is not hot, so water must be seeping out from the Expansion Relief Valve.
I attach photos of my system.
Any help to cure the problem will be appreciated.
