Because I'm planning to have a loft conversion, I thought it would be a good time to consider having a dry loft and installing a Megaflo system - the Heatrae Sadia Megaflo to be installed in place of the the hot water cylinder in the airing cupboard on the 1st floor. I currently have 1 bath/shower room and 1 shower room with another shower to be installed in the loft when it gets done.
The plumber came out and tested the flow rate and said that at 12 ltr/p min the flow rate was not enough for a Megaflo (their min is 20 ltr/p min) and I had 2 options a) replace the mains coming into the property with a bigger pipe at a cost of some £2500 plus with no guarantee that the water company will continue to provide a good flow rate or b) have an accumulator installed which is a tank about 1.2m high and 0.5m diameter for an extra £1000 that will boost the flow rate to about 26 ltr/p min. Not too happy with having yet another tank taking up space and using a technology I had not heard of before, I spoke with the technical person at Heatrae Sadia who advised against the accumulator (wasn't convinced about it) and suggested instead that I leave the cold tank in the loft and install a pressure switch motor on the supply pipe out of the cold tank to boost the rate into the Megaflo.
Now I'm not sure what I should do and not knowing much of Megaflo systems before this, can't decide on the advice, opinions and options I've been given as the choices are so different. I'd be grateful for information if anyone has had any experience with Megaflo systems.
