Looking at the megaflow manual, it shows approximately 7pm on the dial being 60 degrees. I've recently increased the stat a little to make sure this is the case (previously was about 6pm). This has led to two problems:
1) Had to increase the boiler flow temp to 75 or 80 to stop it short cycling when the cylinder is almost up to temp.
2) The water coming out of the taps is VERY hot.
I'd like to have the temperature lower. I can then run my CH temp lower, and get more efficiency, and the water coming out of the taps wont be so dangerous. Do I need to be worried about legionella ? How do most people run their systems ? Having the water so hot seems inappropriate. I wonder, given the megaflow instructions say 7pm is approximate, whether my stat at 7pm represents a temperature higher than 60 degrees.
Ideally, Id be able to control the HW temp separately and use the anti-legionella programme on the vaillant controls (currently using honeywell controls on a standard s-plan), but Im inclined to just lower the stat and get sufficiently hot water without it being scalding. I'd like to hear others opinions on this though.
Thanks.
Thanks.
