Hi guys,
I've got a very odd problem with my Economy 7 Megaflow boiler.
Turned the hot tap on and hot water came out for a minute or two then it went luke warm then it went virtually cold.
I asked my Dad and he said its probably the cold water combination valve has failed or is full of gunk.
I decided to replace the combination valve.
I turned off the mains water and opended the hot taps in bathroom and kitchen and LOTS of hot came out???
So the tank was indeed full of hot water but for some reason it wouldnt come out.
I changed the valve and turned the mains water back on. I ran the hot tap for a minute or two and all seemed well - hot water again.....although I didnt quite understand how there would still be hot water left in the tank after I drained it down?
My misssus just went for a shower and its now running cold again (even after I tried turning on the boost for thirty mintues)
Its as if there is hot water in the tank but for some reason the cold water comes out and the hot water stays trapped inside the tank.....I'm stumped!
