Megaflo Cold Water Combination Valve drip
20 Nov 2009
Nottingham
Hi all, new to the forum and in need of some advice please!
I have a two year old Megaflo hot water heater and I have noticed a drip from the Cold Water Combination Valve :shock:
Few questions:
1. Is there a simple fix for this?
2. If it needs a replacement valve can I just do this myself? (I'm assuming this would mean I isolate water supply, drain hot water tank, remove and replace with new valve?)
3. If I can do this myself, where is the best place to get the part?
Many thanks :)
Please see pics below for the valve I am talking about:-
- Glyn
Strange I went to exactly the same fault 2 nights ago.
I've got the valve cartridge on order. Quite expensive though :cry:
its a common problem even with the old ones. You should really get a G3 qualified engineer to replace it. I'm afraid thats the only advice I can give.
An update, I ordered the part online, it was easy to replace myself.
Just drained the cylinder, allen key to remove the valve screws and put on replacement.
It was fixed for about 6 months and then the replacement started leaking too (another hole developed). I requested another replacement which was provided free of charge under warranty. It's been 6 month's now so fingers crossed this one lasts a bit longer!
