- Joined
- 11 Jun 2019
- Messages
- 2
- Reaction score
- 0
- Country
Hi all,
Ok so thought I would post something on here quickly as it's driving me mad. I'm in the process of having a loft conversion done at the moment and despite the fact they have done a good job with the loft conversion itself they have never got the hot water/heating system right since they moved it up to the loft.
So at the moment I'm finding that the 1 hour boost for the hot water is working and is the only way I'm getting hot water. The timer is supposed to come on at 5am to heat the hot water and go off again at 7am. But it doesn't ever come on. It's supposed to come on again at 4pm until 6pm tonight but I need to wait until later to see if it does but I don't think it will.
Up until last week this was all working fine apart from we had a fault on the boiler that was showing an F2 code which seem to indicate that the flame was going out. This seemed to happen for about an hour in the morning and an hour in the evening on a vicious cycle! The burner would go on, show an F2 code and then start the cycle again.
They seemed to stop this happening but now the timer doesn't work.
Now I have gone back and forth to the builder that is doing the work as they moved it but I'm almost at the point where I am going to say to him you have one more chance to sort it or I'm going to call someone out and knock it off what I owe you. Has anyone had an issue like this with the hot water and with a builder where you have had to get someone else in?
Not sure how many times I can keep getting them back before I say enough is enough I'm calling someone else!
Cheers
Cheers
