I have a lot of GU10 halogen bulbs in my house and decided to replace them with Megaman GU10 11W bulbs as they were on sale for 6squid each from an internet retailer.
They were advertised as direct replacements, but when I came to fitting them it became obvious they aren´t. They are about 8mm too long to sit in the fitting which holds the GU10s in with a circlip.
Looking at another website they give the actual size of the bulbs and the 11W bulbs are about 9mm longer than the 7W bulbs.
So I am thinking of 2 options at the moment:
1) Exchange the 11W bulbs for 7W bulbs, which annoyingly are more expensive. However, I do not know if these will be bright enough. The 11W bulbs are definitely brighter than the 50W halogens and they are the warm white version.
2) Exchange for LED bulbs, which cost an arm and a leg
2) Remove the housing to the GU10s and cut a hole out of the top so that the black plastic connector can sit higher up and allow the 11W GU10s to fit. The problem - I haven´t a clue if this is ok or even why they have a ceiling to the housing in the first place (or why there are different lengths of housing)
Any help is much appreciated.
