megga flow
14 Feb 2008
how can i increase the pressure of a megga flow system.
i havw 2.4 bars static pressure and 1.8 at 18 litres/min
You can't.
Sorry, that probably sounded insulting.
I meant that you cannot increase the pressure beyond what your cold main can deliver. You might be able to improve things if you have a constriction between the water company service valve and your property, or at the stop cock, or inside your house, but that's all you can do.
Can you explain exactly what you want to achieve?
18 litres is a pretty good dynamic flow rate at 1.8 Bar.!
Why do you think you need any more?
Tony
the customer had a 3 bar pump on the shower,and is now unhappy about tthe pressure
OK. That's enough of that.
What are the symptoms of the plumbing or central heating problem that you wish help in solving.
You can't.
He can have an accumulator and a pump to increase the pressure on the house side of a double check valve at the stop cock.
