Melting insulation from thermostat to element on immersion
31 Mar 2008
Essex
I have just installed a new immersion heater and wired it up. Neutral to element, live to thermostat. The wire from thermostat to element (already fitted in unit) is slowly melting/cracking as it is getting hot. Any ideas. I assumed that wire should be able to cope with current in circuit. All other cables are ok. Heater is a 27 inch incolloy element BEAB approved safety system, E9573.
Any help would be greatly appreciated.
Saleem
It is probably due to a loose connection or some other, more serious, problem.
Andrew's advice is probably your best option.
