merlin boiler lockout
8 Mar 2009
Argyll
Hi Guys
I have a problem with a merlin oil boiler with a Sterling 50 burner it will run for days then lock out on restart, checked oil, oil pressure ,nozzle,controlbox,oilpump. will start each time after checking , run for a few days then lockout, any ideas
A Merlin boiler in Argyll?? You must of bought that yourself?? Did you also fit it yourself & has it ever been commissioned by someone that knows what they are doing??
Hi Dick
boufght the boiler second hand Hasd been in holiday home hardly used spoke to the plumber who fitted it when new , said it was a good buy. fitted the boiler myself and had plumber come and commision, only deals with oil no gas where we are. had probs at first then worked fine after new control box fitted, since then started playing up.Cheers
.............has it ever been commissioned by someone that knows what they are doing??
Dick I can only presume the guy knows his stuff, I,m a builder myself and have used him to install systems in new builds , Most people in the area regard him as ok, he doe's have all the equipment but being the only plumber local Don't mean his the best, however if you think it is likely that he's not up to it i'll try someone else.
It could be the ignition unit or photocell is a lesser possibility. It may still be the pump despite having checked it.
