I've got a few problems with my central heating, so hoping someone can point me in the right direction. I have searched the forum to see if anyone has the same issues, and was shocked to see how crap Potterton is - so could be another case here.
Our bolier (Suprima 30) locks out quite a lot, but not in a consitent (or not that I've spotted) fashion that is making it hard to detect what is wrong.
The 3 port valve (so I've been told) in the airing cupboard is on it's last legs and makes a strange electrical/groaning noise when switched on - I have to manually push it over to the Central Heating side sometimes - I think perhaps the motor is struggling.
Anyhooo - the problems...
When we switch on the heating, sometimes it works, but mostly the boiler sits there showing no signs of life until I manually push the lever on the 3-port valve (another potterton unit) into position, at which point the boiler kicks in and all is well.
Sometimes it does it on it's own and there is no problems.
It dies mainly when we're using the system - so if we leave it off overnight, it automatically kicks in without a problem in the morning (when it's cold). Ask it to repeatedly come on in the evening, and it isn't happy!!
If I do not move the lever on the 3-port valve, then the boiler goes into Lock-out. Multiple resets do not work. The *only* way to correct it, is for me to remove power to the system, wait 2 mins and try again.
Problem 2!!
When it's all working - the temp of the pipes on the pump register at near 70 degrees, the water in the tank reads 60 degrees, which the thermostat is set to, but the water from the taps in the bathroom show at nearly 70 degrees.
This scalded us the other day, so a little worried.
I apologise this is a long message, but please help - I've no experience with plumbing.
How much should it cost to have a plumber replace a 3-port valve?
Many thanks guys
Matt.
Problem 2!!
Many thanks guys
Matt.
