Metal Wall Sockets/Switches
29 Aug 2006
Hertfordshire
Hi.. sorry.. but this is a very dumb question.. but I am quite new to this..
When installing a metal plate - I get the fact you have to earth it... but am not 100% sure how to do this.
The existing (plastic) switch & metal box - has an earth - the box is earthed...
So when I earth the metal switch... do I...
a) run an earth from the switch to the the metal box's earth (screw type thing?)
b) Do I split the earth using a connector thingy - and run one to the box and one to the switch?
c) or something else?
Also.. is there such a thing as a 1-way switch? when you jusy want the
switch to turn on one light? - as all i see are 2/3/4 gang 2 way switches???
All help muchos appreciated!
Best
your desciption is a bit vague but i think what your doing is changing a plastic light switch for a metal one.
if this is so...... then connect the earth from the twin and earth cable(s) (making sure it is sleeved with green/yellow sleeving) to the earth connection on the switch which should be marked.
also run a sleeved earth from this point to the back box earth terminal if it has one.
and yes you can get a switch that is simply on/off for one light.
hope this answers your question, any further problems then describe in a bit more detail or post a piccy
:lol:
you can use a 2 way switch as a 1 way (use com and L1).
generally you can get 1 gang 1 way switches but not higher number of gang 1 way switches. Its just not worth making them for the small number of switches where every gang is used as a 1 way.
