We had our house re wired last July by a firm who had opened a shop locally.
Earlier this year, one of the switches tripped. I just thought that it may be something to do with a kettle which we had recently bought.
It only happened another twice over the months.
Then, last week, the meter tripped, and kept on tripping - sometimes just after a few seconds, other times after several minutes.
Then suddenly, all was OK again.
We have a double socket, so the kettle and the cooker were affected.
Today, I was on the computer, and it went dead.
I discovered that my husband's stair lift trip switch, had also cut off.
I went to check, and it was the same switch which had tripped again.
So those four things are all connected somewhere.
(I don't have a clue about electrics).
On the control board, it is the far left hand side switch which trips. A test button is above it.
When the switch is in the on position, it says - 1.on, on the lower side of it.
Under the switch is a square with 14 stamped on it. And under that is a square with a label in it, which reads - RCD.
Now, my problem is that the shop has closed, and the owner has vanished.
What should I do? Is this safe, or are we liable to go up in flames?
Advice would be gratefully received.
