    Dismiss Notice
Switch ‘RCD Controlled Circuits’ tripping after new extension
Discussion in 'Electrics UK' started by steveinoz01, 10 Dec 2017.
  1. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,857
    London
    Country:
    Something is wrong, but the behaviour you describe is normal - MCBs always remain on when an RCD trips.
  2. Sponsored Links
  3. John D v2.0
    John D v2.0
    26 Aug 2016
    6,315
    Thanks Received:
    876
    Country:
    To the OP, was it the big switch ban all sheds has circled that tripped? And not the similar one further to the left that says main switch? If you switch off the"oven" switches does the ovens "cookers" go off? How about the switches marked "hob"
  4. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,857
    London
    Country:
    Steve - do the ovens go off if you turn off the other RCD?
    • Like Like x 1
  5. John D v2.0
    John D v2.0
    26 Aug 2016
    6,315
    Thanks Received:
    876
    Country:
    Ban all sheds I just want to confirm everything as there appears to be some switch confusion, and the op admitted it was very busy in the house at the time.
  6. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    3,725
    Thanks Received:
    741
    Durham
    Country:
    You appear to have 2 RCDs in that board- one (in the middle) is labelled as MAIN SWITCH which isn't helping anyone
    • Like Like x 1
  7. Sponsored Links
  8. JohnW2
    JohnW2
    28 Jan 2011
    45,437
    Thanks Received:
    2,901
    Buckinghamshire
    Country:
    That was first noted right at the start (post #4). However, that second RCD (the one presumably serving the two circuits labelled 'ovens') is apparently not tripping (when, I think we are being told, the ovens stop working).
    Kind Regards, John
  9. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    3,725
    Thanks Received:
    741
    Durham
    Country:
    Oops- missed that. soz :(
    • Like Like x 1
  10. steveinoz01
    steveinoz01
    26 Jul 2014
    97
    Thanks Received:
    3
    Warwickshire
    Country:
    Just to close off my original post - the electrician finally came back and disconnected each competent one at a time. It took a few visits as the tripping out would sometimes take a few days to reoccur. Eventually he checked the smoke alarms and found a wrong connection and we have not had the switch trip for about a week. Fingers crossed this was the only problem causing it to trip.
    • Like Like x 2
  11. Iggifer
    Iggifer
    8 Sep 2011
    4,637
    Thanks Received:
    587
    Warwickshire
    Country:
    Good news but that’s odd. Smokes are powered 24/7 so should have caused the problem consistently but if it’s fixed it’s fixed
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
