So that descent is not all bad.The usual descent into waffling nonsense has begun, good bye.
Make a note, chaps, of how to get him to go away in the future.
I suspect that he was probably lying about that, too.Make a note, chaps, of how to get him to go away in the future.
Not by my readingWell, it was the Op who mentioned it first ...
Then efli brought up ovensWhen the switch goes we lose downstairs lights, sockets and cookers.
The two ovens would appear to be 'on' the other RCD
Then the op made it clear they didn't know the RCD covers all the circuits to the leftDo you lose any circuits not on that RCD?
He is focusing on the switches mismatch issue not the actual appliances at this pointThe only switch to trip is the one labelled ‘RCD Controlled Circuits’. .......
Is it right that the oven and kitchen sockets stop working even though their labelled switches on the board remain ‘on’ and it’s just the RCB switch that’s off?
Fair enough - I was looking at EFLI's second reference to the two ovens, forgetting that he had mentioned it earlier.Not by my reading...
... but I accept that you may be right in your assumption that 'cookers' meant just the hobs, not the ovens.When the switch goes we lose downstairs lights, sockets and cookers.
Yes, I understand that. You may well be right - as I said, that would certainly mean that the OP'd experiences would make a bit more sense.Then the op made it clear they didn't know the RCD covers all the circuits to the left ... He is focusing on the switches mismatch issue not the actual appliances at this point
It only happens when we have a house full with two cookers in use, ...
All-RCBO setups are, in my opinion, not necessarily 'all good' in terms of fault finding. They probably could be if (like, I believe, is the case with some very expensive bits of kit) they gave an indication of whether they had tripped as a result of over-current or residual current.Could well be, so maybe Rocky's suggestions want so bad!
Agreed, and very expensive! I wasn't clear I was replying to youAll-RCBO setups are, in my opinion, not necessarily 'all good' in terms of fault finding.
might be accumulated small leaks to earth
Yes, I realised that, and I also agree that having RCBOs (or, I suppose, umpteen RCDs!) can go a fair way to reducing the 'accumulated small leaks to earth' problem - although it may not be as good at that as one may think, given that it is probably quite common for a lot of the 'small leaks' to arise in the 'ground floor sockets' circuit.Agreed, and very expensive! I wasn't clear I was replying to you
TBH I have never understood this.There is obviously confusion between two cookers and the oven - when there are circuits for hob and two for oven.
