microbore heating
13 Mar 2008
Surrey
I have a rad upstairs and one downstairs not getting hot even after being bled and bled again, any tips would be really helpful!!!
HI
try these
1.open both radiator valves .remove any plastic cover from the valves as they can give false results. instead use spanner
2.gently tap thermostatic rad valve with a hammer, if fitted
3.might need balancing = in turn close the rad valves by a quarter turn
( radiators that get hot very quick )
4.if above fails then valves or pipes might be blocked.
