- Joined
- 31 May 2016
- Messages
- 25,389
- Reaction score
- 5,633
- Country
I think my mid-position valve has packed up as the boiler is only driving the hot water at the moment and the boiler keeps powering down, despite rads being cold. I've put it in the manual open position for now, which seems to work as a temp fix.
I'm not being tight, but don't really want to drain the system anytime soon.
Is there a way to test the motor?
I'm assuming these are 230v AC motors, so I could put a test meter on the supply to see if its getting power. Does the valve open when the controls are on (e.g. HW, heating). i.e. pressing the override for hw and heat should activate the control?
Are these heads a standard fitting? could I buy a new one and just fit the new head and not replace the valve?
Or if I have to bite the bullet, are they all the same size, i.e. a new valve will fit in the same space?
I have an ACL Lifestyle valve, looks like this:
