My Miele G646SC has developed a water leak between the main circulation pump and the main filter housing. It just drips into the water collection tray and trips the flood protection switch. This stops the machine from running and then continually run the drain pump until the water evaporates away or the water is tipped out. I normally try to repair these types of fault myself. Any advice on the practicality of this and the basic sequence to dismantle. It looks as though the whole pump and motor assembly needs to be removed. Any views on the cost if using an independent engineer. Miele seem to want £250 albeit with a years warranty etc for any other fault. Many thank for any help.
