Miele T294C tumble dryer no power to element
10 Apr 2013
Hampshire
I've just joined after reading many helpful posts and am hoping that someone can help me on this issue.
I have a Miele T294C tumble dryer and on a normal cycle it runs for about 2 minutes before stopping and beeping a lot. The "finish" light is on solid and the "machine iron" light flashes. The Miele book says to contact their service dept.
After reading on here, I have tested the resistance/continuity of the thermostat, front and rear NTCs, and the heater element. All are close to normal values.
I have (carefully) checked the feed to the heater element whilst in operation and there is no voltage there.
Any suggestions anyone?
Thanks in advance..
Ok, so I decided the problem probably lies with the heater pcb. However one of these costs>£100 so I removed it to have a look. There were 3 relays, one of which had some discolouration around its contacts. Tested it and found the relay had definitely failed. I have now removed it from the pcb and ordered a new one for less than £2. Fingers crossed for a successful cheap fix...
can you tell me where you got the relays as my machine has an identical problem...and did the relays pull of the board or were they soldered?
Hi there.
I got the relay from RS Online and the reference number was 256-3165. They were £1.80 each. There are 3 of these on the heater PCB and they are soldered on with 6 pins going through the board. When I looked at the back of this board it was obvious which one had gone as there was dark discolouration around the 6 solder points of the failed relay. So I only replaced the one. It is still working well 6 months later. Feel free to ask if you have any questions.
Terry.
