hi
just been given this machine with fault. It starts fine but rinses light pulses occasionally, after a few mins time indicator shows --- & rinse light flashes, machine drains then stops. I checked brushes as per instructions on a previous posting but they seem fine, one being a bit more dusty than other. When I first got machine it would do spin cycle completely without problem. Now after checking brushes it only runs for 1 min on spin cycle before it shows fault & stops. Rinse light seems to flash each time drum turns. As it now seems a bit worse since checking brushes could it be a bad connection somewhere? I did make sure motor casing was clean where resistors ground on it. Help !!!!
