- Joined
- 20 Jan 2010
- Messages
- 9
- Reaction score
- 0
- Country
The bearings on our W865's motor have gone and I am trying to replace them. I have successfully replaced the one closest the commutator but having difficulty replacing the one at the other end of the shaft.
To get at the other one, you need to remove the belt pulley, which is held in place by a screw with a torx head. Whilst trying to remove the screw, the torx wrench slipped and damaged the torx head.
I've tried cutting a slot into the screw and using a flat blade screwdriver to unscrew it, but it just isn't budging. To make it worse, I'm not even sure which way the thread goes.
Any help/suggestions would be much appreciated!
Thanks!
Thanks!
