Hi, I'm a new member and hope this is the right forum. Apolgies if it isn't. I've partly dismantled the electric motor from my Flymo mower in order to replace a bearing; there is clearly some play on the shaft. The problem is trying to remove the pully on the end of the motor.
As can be seen from the picture, to get to the bearing I need to remove the pulley. I assume the pulley is screwed on, but left or right-hand thread? The difficulty is being able to grip the shaft at the other end while applying pipe wrench to the pulley. Is it possible that it is not threaded? I can't apply any heat because of the plastic housing and fan. If I can remove the pulley, I can replace the bearing for less than a fiver; a new motor is about £40! Any suggestions would be welcome.
