First off, hello everyone, I'm newly registered but have been frequenting these forums as a guest for quite some time now for all my DIY needs and now I'm looking for some advice which I've not come across through the search function. So yeah here I am and I'll do my very best not to be a pain in the *rse.
A few days ago we had a good 16 hour non stop period of medium to heavy rain that continued well into the night, it was at this time I noticed a tiny leak that started on the ceiling corner and worked its way behind the coving and down the wall.
The next day after work and also when it had stopped raining I checked again and it was dry as a bone, I took a look outside at the roof and guttering and there is no obvious visual damage to either so I decided to look in the loft. After getting to the corner above the room I couldn't see any sign of wet on the beams, brick or the insulation but I did find a ten pence sized hole in the black lining just above.
I've stuck an old flattened cardboard box directly underneath the hole not as a fix but in the hope that next time there is heavy rain like that again I'll be able to see if it marks the box revealing the hole as the culprit.
If anyone could give me any other ideas, or anything I've missed that would be great. Thanks in advance.
