I’ve just moved into a persimmon new build (2 yr old) but we are the second owners, the first owner had a power shower fitted to the main bathroom, the en suite has a shower that is mains fed, hot and could strip paint it’s so powerful…..we had to fit a reducer on the shower hose.
The main bathroom shower is fine on cold but if you turn it up to hot then it’s very under pressured, you can shower with it but it’s annoying.
The bath is one of those baths that have a safety wadjamacallit under the panel I imagine as it doesn’t get too hot… could this effect it.
From what I’ve read I suspect this is just cold fed so wouldn’t be influenced by that…. So is it just slow because it is cold water and needs to be heated by the shower? If so, why would anyone bother with a ‘power shower’ if I mains fed shower would’ve been so much better….?! Although I’m guessing you may not have the answer to that last one
