Mira essentials 95
13 Apr 2012
Hi
I have came across a problem with my Mira essentials 95
After pulling cord and engaging push button on the dial there is only a half circle of light showing where it should be showing a full. After taking off the cover it appears the bulb has blown with the wires attached to the water tank. Checked the inline resistor was showing open, on the other side checked the resistance and it showed a healthy 150 Ohms approx. I guess the resistor has failed and hence too much current has blown the bulb and MAYBE this is the signal to the tank
I imagine all it will take will be a new bulb and resistor, but it’s a bit of a hassle with crimping etc, is it possible to replace the whole part as it would just mean unscrew from the tank, pictures below also
If anyone has came across this problem before can you please advise?
Get a new neon assembly.
Pt No 439.74 about £8.
This won't stop the shower working.
