- Joined
- 6 Nov 2007
- Messages
- 1
- Reaction score
- 0
- Country
Hi everybody. On returning from a holiday my mira excel was running lukewarm no matter what temp i turned it to. On reading up on internet and advice from an engineer i was told i needed to replace my cartridge.
On replacing the cartridge the shower is still only really running warm when normally 2 on the temp gauge was hot enough before. The shower is drawing hot water from the combi (worcester 24)
Could anything have happened in the week it wasnt running maybe? Is the factory set temp normally hot enough or would i be better of trying to adjust it on the new cartridge or any other ideas or maybe just call a plumber in.?
I recently had my hot water tank taken out so the shower is fed with mains pressure now. Could the problem be down to unbalanced inlet pressures due to the mains being a lot more than the combi boiler. The plumber that done the work said that maybe a presure reducing valve maybe needed but he didnt fit one. The shower would also squeal sometimes and the handle to turn it on and off would be stiff (which since knowing little about plumbing i put it down to age since its just over 5 years old)
Cheers in advance
Cheers in advance
