Mira sport Airboost fault
26 Jan 2009
Bristol
I have a Mira sport Airboost shower. The unit is turning on but no waters coming out and the light on the low power button is just flashing…
Any ideas?
Sounds like the solenoid has failed. Do you have a multimeter?
Measure the resistance across the two terminals of the solenoid ,disconnect one of the cables going to it ,after you isolate the electric supply to the shower, before taking the reading. Tell us what the reading is.
If you don't know what setting to use on the multimeter ,show us a pic of it ,and we can advise you.
  • Thanks
Reactions: CBW
As per Terry, measure the resistance measured in ohms
Ω this symbol, sorry, the site wouldn’t let me edit previous post.
It doesn’t appear to be. Next try the thermal cut out (tco), it’s a simple continuity check (that’s the one that looks like a wi-fi signal, or a speaker volume.
