mira sport low pressure
19 Sep 2004
What could be possible cause ?
Disconnected supply pipe and the pressure seems ok.
Low pressure light is on constantly and the shower is a little more than a
trickle
just registerd on the site seen your roblem had the same myself you will find that there is a little circuit board in the shower unit which tells the flow transducer the pressure is ok this is what has gone in your shower you will need a new one and they are quite hard to find you might have to try mira directly i got fed up and changed the shower .........good luck
