    Dismiss Notice
Mira Sport Max 10.8kW Shower keeps running on cold after switching off
Discussion in 'Plumbing and Central Heating' started by David Cook, 5 Nov 2019.
  1. David Cook
    David Cook
    5 Nov 2019
    Thanks Received:
    Country:
    I know that this shower has a design/safety feature which lets the water continue to flow for just a a few seconds and gradually cool down after it is switched off. Recently the length of time that the water continues to flow has increased significantly and it now runs for at least 15-20 seconds, where the water temperature is very cold for the last 10-15 seconds. Does anyone have any suggestions as to the cause and possible cure for this? Thanks.
  2. ReJect
    ReJect
    19 Oct 2019
    296
    Thanks Received:
    62
    Country:
    It won’t do any harm running on longer as long as shower works otherwise normal.
    But I would assume it is the phased shut down board that is faulty
    • Like Like x 1
  3. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    2,023
    Thanks Received:
    254
    Country:
    It only has one PCB I think, so it would be an expensive entire board replacement. I would guess first at a sticking solenoid valve.
    • Like Like x 1
  4. ReJect
    ReJect
    19 Oct 2019
    296
    Thanks Received:
    62
    Country:
    Sounds a likely suggestion.
  5. Sponsored Links
Loading...
Share This Page
