Hope someone can assist please
Just replaced the shower with a Mira Sport Max air boost 9Kw
Ran OK after the plumber installed it, but then started having issues next day
High mode- runs for a minute or so then stops working, no water comes out, there are no lights lit on the shower front as though we have lost all power, but the main fuse doesn’t trip, so I know their is power still at the shower.
Have to wait a few minutes, press the on button and it works again for a few minutes then same again
Have also noticed if we move the dial far into the red zone the water is scalding, although moving it back will run at normal temperatures, I didn't think modern showers would allow scalding water?
So I tried it in Eco mode and the water ran warm and didn't fail ,worked OK for 2 days
But this morning had the same fault as in high mode and it stops working, no lights on and no water (water isn't scalding in this mode)
Also noticed this morning when the fault occurs in eco mode, the low light was flashing, but according to the Mira guides this is not an indicator of low pressure, just indicates its in the low mode
Also run it in the Low mode and as per user guide runs cold water, no issues in this mode
Rang Mira tech guys and they admitted never heard of all these faults . especially where there appears to be no power, but there is and they advised it's probably a faulty shower.
Before I go through the hassle of getting it replaced, has anyone any thoughts/experience on the above issues please
TIA
TIA
