Mira sprint 9.5kw no power
19 Sep 2010
Lancashire
Hi, we have a mira sprint 9.5 kw electric shower which is over 2 years old and has been working fine, until yesterday when i turned it on and nothing happened, no power light came on and no water came out.
The power light comes on on the pull switch, i've also had a look in side the pull chord switch and all the connections seem ok, i took the front off the shower and checked the wires are still connected, which they are.
Is there a fuse some where which could have gone or might it be somthing else?
any ideas?
In the absence of the shower unit being u/s:-
Always safely isolate first
If the pullswitch light stays on while the shower is attempting to be operated then the connections should be ok up until the pull switch. If the load connections are ok in the pullswitch (check by safely isolating first) then I would suspect a the shower unit itself.
If the pullswitch light goes out when shower is trying to start then there could be a poor contact in the switch mechanism or loose connection at the consumer unit. Do not attempt to try and find this yourself unless you feel competant/confident to do so as there are still live terminals in there when the main switch is off.
