I never thought mist coating would leave me in the wilderness, but I have a dreadful sinking feeling I have a more than just a small problem here.
I am in the the middle of a whole house refurbishment (an ongoing hell already several years in process) and have just finished mist coating two rooms.
An architect friend advised using the same brand and type of paint for misting as would be used in later coats. A decorator (who seemed to be doing good work) when out visiting an acquaintance said I might as well use the same paint for the mist coat if that meant I could by a 10 litre tub and that vinyl matt would be fine since my walls were skimmed well over six months ago.
The paint is Dulux Trade Vinyl Matt (PBW). That same decorator recommended 3:2 for misting (saying anything less would be way too thick for Dulux trade). I mixed a small batch, brushed it in. It absorbed well and seemed to do as it should ... into the plaster, not on the surface, only came away if scratching away the plaster itself.
For the full job, I brushed the edges and rollered the large surfaces. I tried to work fast, trying to make sure that the paint got worked into the plaster, and not just the water sucked out of the mix. It is a messy and miserable job as all know, but job done! Happy ...
24-36 hours later, concerned and no longer happy ... caught the wall with some low tack masking and off pops the mist coat. Ok, maybe it is a fluke. No, seems to happen easily. and everywhere.
So I waited another 48 hours hoping maybe the paint would cure a bit better. No joy. still just as bad. tape still lifts away the paint. It seems to take a bit of plaster with it (although not much since the surface looks reasonable underneath). Paint layer is also too thick; it is possible to scape / flake away where the tape has lifted.
In doing these large areas I was really surprised at the opacity of the mist coat, but then again it is trade I thought to myself at the time. Bonus? Or not? Did it go on too thick (yes, almost certainly)? Did the water still get sucked out too fast (probably with vinyl just sitting on top)? Did it really still need to be brushed in and was rollering a mistake (almost certainly, seems to have laid down much thicker and more on the surface)? Well, this is what spins in my mind as I think about how this may have failed so miserably.
SHMBO (but will not pick up a paint brush herself) has reached deep into her soul for a whole new glare that I did not yet know existed. (She, as am I, is fatigued by the project but she watches DIY programs and thinks that we should have been able to redo a complete 3 bedroom semi in a 30-minute episode, maybe 60 minutes if it is BBC prime time). I am rather disheartened to put it mildly.
As far as I know there were no problems with the preparation of the surface:
- thoroughly dry
- no pva was used in the plaster (to my knowledge), although it was used on the surface prior to plastering
- no pva (or similar) was put onto the plaster after
- plaster not glassy by any stretch of the imagination, indeed visibly porous
- mesh sanded to removed snots, etc after patching holes and trowel marks, etc
- wiped down and vacuumed to remove dust so as only leaving a very slight amount of dust on a clean latex glove swept across the surface
- thoroughly scouring various forums I now realise that I could have certainly done myself a favour by wiping down with a damp rag, but that seems to have been a 'nice to do' and unlikely to have been the main problem.
I have a feeling that the remedial work is going to be excruciating. (Alas, lining paper is a non starter here.) But, if you have real expertise in this area of problem / solution, please don't hold back. I can't have the paint failing the first time a child blue tacks a poster to a wall or a balloon to a ceiling.
I also understand that it is important to point out for those who will follow on into this thread to point out what I did wrong. (For one, no matter what anyone says, I'll never mist with vinyl again, no matter how dry the walls). However, what I really need most is help finding a solution.
Thanks for reading!
K
And, BTW ...
I am a great fan of the forums here and reading through them has certainly helped keep me clean up a few problems and keep clear of many others in the past too. So as a first time poster, a comparatively new registered user, and a long time lurker, let me say thank you to all who have contributed to making this forum such a wonderful resource!
- thoroughly dry
Thanks for reading!
K
And, BTW ...
