    Dismiss Notice
Mist coat has left a chalky finish, final cost flaking/lifting
Discussion in 'Decorating and Painting' started by John2016, 16 Feb 2021.
  1. John2016
    John2016
    18 Jun 2016
    72
    Thanks Received:
    2
    Country:
    Hello,
    We recently had our kitchen skimmed, when it was completely dry (2 weeks) I decided to apply two coats of mist (50/50) coat leaving 3-4 hours in between each coat.
    The paint I used was: https://www.wickes.co.uk/Wickes-Matt-Emulsion---White-10L/p/145119
    Honestly, I didn't read the reviews before purchasing, I was passing wickes and thought I'd pop in.
    I picked up some Dulux Easycare Kitchen tester pots and when trying them out the paint started to flake.
    I've applied mist coats before and never had any problems, however, this time round when I run my hand over the dried mist coat paint, its like chalk.
    Whats the most practical advice on having this resolved? I don't really want to wash/sand down all the walls and ceiling. Could I just get a contact Matt and paint over the mist coat with two coats and then apply the finish Easycare.
    Thank you.
  2. Sponsored Links
  3. sparkwright
    sparkwright
    20 Aug 2009
    8,144
    Thanks Received:
    1,010
    Dorset
    Country:
    Despite claiming to have high opacity (it doesn't according to reviews) I think this retail paint is too thin to be diluted as much as 50.50.
    Out of interest, does the paint wipe off the wall nicely with a damp cloth?
    I only ask as it may be problematic to try to paint over this.
  4. John2016
    John2016
    18 Jun 2016
    72
    Thanks Received:
    2
    Country:
    Yep with a damp cloth and after a few going over it does wipe of to bare plaster. At the back of the paint it does say to add up tp 40% water for new plastered walls, however, mime were skimmed, if that makes a difference.
  5. sparkwright
    sparkwright
    20 Aug 2009
    8,144
    Thanks Received:
    1,010
    Dorset
    Country:
    Newly plastered = newly skimmed, as far as painting should go.
  6. John2016
    John2016
    18 Jun 2016
    72
    Thanks Received:
    2
    Country:
    Understood.
    How would I go by resolving the problem?
  7. opps
    opps
    16 Jun 2006
    4,580
    Thanks Received:
    718
    London
    Country:
    40% water sounds like a lot for a very, very thin paint.
    I would phone wickes and complain.
    You could buy some Dulux trade matt emulsion and thin it- one part water to 5 parts paint (17%)- and see if that works as a mist coat. If not wash the wickes paint off (messy) or use an appropriate Zinsser primer (expensive).
  8. Quilts76
    Quilts76
    19 Feb 2021
    24
    Thanks Received:
    2
    Country:
    We had this on a job and was told the plaster was at fault and possibly out of date.
    Zinsser primer as above maybe the only option.
    • Like Like x 1
  9. Sponsored Links
  10. opps
    opps
    16 Jun 2006
    4,580
    Thanks Received:
    718
    London
    Country:
    Good call.
    Now I think about it, I have noticed something similar where I am currently redecorating. A small section of recently plastered and painted (by the builders a few months ago) is chalky. I had assumed that it might be salts in the plaster but haven't gotten around to addressing it yet.
  11. John2016
    John2016
    18 Jun 2016
    72
    Thanks Received:
    2
    Country:
    Thanks, I assume this is something which would go over the mist coat? Removing the mist coat in the ceiling is going to be a pain.
  12. lowster
    lowster
    13 Apr 2011
    80
    Thanks Received:
    Leicestershire
    Country:
    Did you ever find solution to this? I have the same problem, the mist coat 25% water to 75% crown trade emulsion has left a chalky flakey finish.
    I'm in the process of washing it all back off with a sponge and water. Don't know what the next move is?
    The surface is still quite dusty, do I use an acrylic primer like Mapei primer G and then paint on to that? Anyone in the know have any idea please?
  13. John2016
    John2016
    18 Jun 2016
    72
    Thanks Received:
    2
    Country:
    Lowster, what does it say on the tin for fresh plaster?
  14. lowster
    lowster
    13 Apr 2011
    80
    Thanks Received:
    Leicestershire
    Country:
    Hi, The Crown tin says up to 40% water for a mist coat - I kept it well within the recommendation but it just doesn't look right. (Is that how a mist coat should be?) I wouldn't trust painting over it, if I run my hand up and down the wall, there's a chalky pile of paint dust on the floor...
  15. Wayners
    Wayners
    24 Oct 2020
    264
    Thanks Received:
    73
    Country:
    Prime plaster or anything chalky.
    Acrylic primer undercoat is good and if I have to use dulux easy care then I get it tinted to match as a primer.
    Gardz is good but clear.
    Beeline sealer is cheaper and also good but follow the guide on thin or its like glass. It's good value.
Loading...
Share This Page
