Mist Coat using No Nonsense Trade Contract Matt
12 May 2011
Cheshire
hi all
we have fresh new skimmed walls, they are dry and today i went about using No Nonsense Trade Contract Matt (screwfix own brand) as a mist coat, ive done 1 coat so far and watered it down slightly, rolled on and cut in with a brush
will this be enough to seal the plaster? i intend to use 2 coats of my desired coloured paint
having just read the tub it says to use 2 coats on fresh plaster and not to water down, but if needs be up to 10% water.
so a bit wary now, what do you guys think?
thanks
Its a bit strange saying not to water it down. The whole point of a mist coat is that the extra water you put into the paint sorts the thirsty porosity of the plaster. It could be that the screw fix stuff is very thin but if you fail to water down the initial mist coat the plaster will draw in the water from the paint and cause it to be crispy. If the coat you've applied seems to be well adhered there is no need for a second coat. I've bumped Mr H's post so you have some reading.
