Mitre Join
20 Oct 2007
hi,i am using a basic mite saw (non electric) and i'm a bit stuck now as i need to cut 25 and 32 degree angles while the sw doesnt cut less than 45 degrees.
appreciate any tips of how i can get around the issue. thanks
the best way i find if i don't have a miter saw, is screw a 800mm long 2x3 to a 150mm x 800mm piece of 12mm mdf center it along the length mark the angle on the top and square it down the side, cut this very accurately then use this as a miter block.
sorry if that doesn't make sense, not that good at describing things. if you don't understand, just say and ill try and get a photo.
ad
0n the back of the saw at the pivot point you are likly to find 2 alen[hex]screws you position the saw to the angle you want then tighten one off the screws
