Hi All,
I'm in the plumbing and heating section, but I think it is the nearest for an Air Con question - so here goes.
I am refurbing a flat in Spain and I want to install a combined air con and heat system. I will use the two part units, being the fan unit outside and the inverter in the rooms (is this correct so far?). Having looked at the internet i can see that some fan units can drive a number of inverters and this would make sense as it would reduce the cost and wiring requirements and space used outside, maintenance, etc.
So the question is this, are there major compatibility issues between the fan unit and the inverters or can i mix and match. I have been offered a fan unit and two inverters by somebody, but i will need two more inverters to finish the job. Assuming that the fan unit is up to spec for 2 extra units, can i just buy these irrespective of make and model or do they have to be the same make as the fan unit. Could i buy a couple of ebay inverters of different makes to save some money, etc or will i run into trouble?
[Yes, i will be having a professional installation by the way.]
Hope this makes sense and thanks in advance for the help.
