Hi, we have an ongoing saga with regards to trying to fit a large (2100x1400mm) skylight into an area of flat roof over piched sides above an existing double story extension. We originally wanted an open shaft through the roof void (approx 1000mm) to the room below but as the construction is trusses this has proved to be too expensive to achieve for the benefits it would yield.
Therefore we are now considering the option of having the same size skylight but leaving the trusses intact and building the shaft (splayed on the sides) around them so they would be visible from the room below.
We have spoken to our local BCO who has said that the insulations levels required would be at current standards rather than the over ceiling rockwool we currently have.
So the current list of questions are:
1) As the roof is of a mixed design i.e. pitched with a flat top which U value should we be aiming for as it seems there is a different requirement for flat roofs and for pitched?
2) I assume the new shaft through the roof void would need to be insulated but again what U value are we trying to achieve for this aspect?
3) The skylight has a U value of 0.6 W/m2k which appears to be well within the requirements for skylights but does the roof taken as a whole have to meet a minimum insulation level or is each separate component assessed individually?
One last thing what types/methods of insulation would be appropriate for each aspect? I know it's a big ask but if you don’t ask..................
Many thanks.
