Help, my shower refuses to heat up so I've been stuck with lukewarm to cold showers for a few months now. I'm finally anoyed enough to do something about it so need your help!!
The shower is largely hidden from view with only the mixer tap and shower head protruding from the wall. However turning the hot-cold tap makes absolutely no difference to the temperature. All the other hot water taps in the house work fine.
The only way I've found to get a partially hot shower is by turning the cold tap on in the sink while the shower is on full. This seems to divert cold water and allow sufficient hot water through the shower.
Can anyone please advise on probable causes of this problem and how to fix (without calling a plumber!).
Many many thanks
Many many thanks
