    Dismiss Notice
mixer shower valve is it faulty??
Discussion in 'Plumbing and Central Heating' started by gillsboy2010, 30 May 2012.
  1. gillsboy2010
    gillsboy2010
    2 Jan 2011
    63
    Thanks Received:
    Kent
    Country:
    hello,having problems with me onsuite shower,it has been ok since it was fitted in 2004,just getting cold water ,was hot and cold stop start,now cold only,thought it was me boiler but the sink is ok so do these mixer valves go wrong??it does not have a thermostat,just straight forward manual mixer?? :?:
    thanks pete
  2. seco services
    seco services
    3 Dec 2007
    15,699
    Thanks Received:
    1,259
    Essex
    Country:
    What shower make/model is it ?
    What happens when on hot setting ? are you getting water but cold or no flow at all ?
  3. Sponsored Links
  4. woolyhead
    woolyhead
    10 Jul 2012
    11
    Thanks Received:
    Country:
    I have the same problem but with a Triton LP 3000. I wonder if it could be caused by a blocked hot feed pipe to the shower, such as limescale? I've asked this question myself, today, on this forum. Let's see what the experts say. How old is your shower? Mine is 14 years old. Is it better to refurbish it/clean it out or get a new one, do you think?
  5. woolyhead
    woolyhead
    10 Jul 2012
    11
    Thanks Received:
    Country:
    Hi again. I think the problem could be a sticking hot water inlet valve. Triton says I should clean it now and again to remove debris. If it sticks it only allows an amount of flow according to the position where it stuck. This may mean that insufficient hot water is allowed in. Does anyone know what the function of the inlet valves are? The booklet says "they prevent crossflow of water, either hot or cold." If this is all they do then what controls the amounts of water coming in to the mixing chamber?
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
