Mixer showers on two floors
23 Oct 2009
Cardiff
I have just had an en suite bathroom built in my attic conversion with a mixer shower running off my combi boiler. I am now about to tackle my main bathroom which has had two electric showers break down. I think the mains cable is the wrong voltage as it looks burnt! Will it be ok to have two mixer showers running from the combi boiler or should I get the elecrics sorted out and have another electric shower.
Thanks to anyone that can help.
3 Dec 2007
Essex
you can have another mixer but doubt you'll be running them together.
your combi probably won't give enough hot water flow to run two.
as in the electric shower is handy for when the boiler may break down you still have a hot shower.
3 Feb 2008
Northamptonshire
As seco said, an electric shower would be good backup should your boiler break down. You MUST get that wiring checked out by a qualified electrician though. A shower takes a lot of current, if the cable is too 'thin' it will get hot, and could possibly melt and/or start a fire.
Showers need their own dedicated supply from the consumer unit (fusebox) and a thick enough cable to handle the electricity requirements. If unsure, a definate job for a electrician really, you have water and electricity (a lot of it), in close proximity, a dangerous mix if not done correctly.
8 Apr 2008
Essex
I would go for the two mixers off the combi especially as its your main bathroom with the electric shower at the moment, why put up with the crappy performance of an electric shower because your boiler might break down once in five years.
