Hi there,
I’m about to move into a new flat (renting) and am thinking of dabbling in a bit of x-10. My main aim is to create ‘mood lighting scenes’ in the main living area that are easily changed by a press of a button. I’m new to all this but I have been looking around the net and have decided on what I want to achieve. I think it’s pretty simple but I seem to be restricted by the lack of UK x-10 products and my bank budget.
The ‘victim’ room has one light switch at the entrance that simultaneously operates 4 light fittings (ordinary house bulbs). This switch will be replaced with an x-10 compatible wall mount (preferably the same size as the existing one because I can’t really modify the fitting) with dimming capabilities. Ideally I want something that has specific ‘scene’ buttons similar to this:
http://www.smarthome.com/23796.HTML
Can this wall mount be modified to work with 240v’s? Has anyone done this before? Can anyone suggest a reasonably priced UK alternative? I have read that people are using the US style RF receivers with a little modification; can this also apply to the wall switches?
In addition to this, I intend to have 2-3 plug-in lamps scattered around the room connected by standard x-10 lamp modules. In principle, the wall switch should be able to operate the existing wall lights and any x-10 lamp modules I have. I also envisage a RF receiver somewhere so I can control all this from the sofa.
Any help would be greatly appreciated. Due to the fact that I’m renting this flat I need to install all this without modifying the fixtures and fittings.
Thanks for reading this far!
Wayne
Wayne
