more breaking glass
16 Jan 2006
Wiltshire
A few weeks before Christmas we suffered a similar problem (breaking glass) with six of our double glazed units fitted in Georgian sash hardwood frames, all cracking within a 3 week period. A single DG unit is fitted in each sash, with the glazing bars glued to the outside with silicone. All installed between 7 & 8 years ago, never had a problem before. Each window has cracked, either inside or outside pane, the crack following the line of the glazing bars. 5 of the six failures happened shortly after painting the inside frame with Satin wood paint - there has to be a connection. The installer claims not to have experienced this before, so is not at present offering replacement under guarantee. Looking on the internet it sounds like a combination of thermal conditions (cold temperature), & deteriorating seals - any thoughts? Dare I risk painting any more windows? Should I specify replacements to be toughened glass?
__________________________
lynda, moderator
BandB, please don't hi jack posts
This is fairly common it mainly happens in the winter it really only the diiferent expansion rates of the glass and lead, the aint anything you can do about it
My windows aren't leaded, but the glued-on wooden strips may have an effect if they absorb moisture and expand.
